trailering an i/o motor...lift? or not?
This_lil_fishy
Master Chief Petty Officer
Re: trailering an i/o motor...lift? or not?
I often use the trailer button to raise it higher in shallow water and have never encountered a problem. Similarly, when starting the boat near shore, we often run it with the drive quite high. It makes no unusual noises and doesn't seem to have hurt anything. That's with a Mercruiser, but it could be different with other makes.
My mercruiser manual states very clearly not to exceed 1200rpm in the trailer position....the one time I did exceed that I could very clearly hear the U-Joint working very hard. It was accidental, but I never do that anymore.
Ian
northernmerc
Ian
That makes sense. One would not want to rev the engine anyway with the lower unit raised; doing so just raises a lot of turbulence and doesn't accomplish much. 1200 rpms is enough to slowly move along until one can lower the motor in deeper water.
df909
Tilting the drive up (trailer position) is not a great idea with the Merc's at RPM's higher than 1200 like everyone else said. If you find you have to power like this, I'd also worry about dirt/debris in the water intake and hitting the hull against something.
In other boats, such as the early Volvo's, you couldn't power with the drive tilted at all. The Merc's are handy since it makes boating a bit easier.
PiratePast40
+2 ^^^^ what he said^^^^^
If you look at the lift mechanism, it'll scare the heck out of you when you think of the outdrive bouncing on it going down the road. With the bracket, you're not stretching the bellows that much so it's really a non-issue.
ChampionShip
Lift up for clearance during transport- not many outdrives can negotiate leaving a driveway in the down position without hitting the skeg, store it in the down position to keep wear and tear on the bellows to a minimum and to let all the water drain out if it's cold.
-Champ
