Mercury tilt/trim 50 HP 2 Stroke Problem
Randy Walker
First time on the Forums. I have a 2002 Tracker with a Mercury 50 HP 2 Stroke. The tilt/trim works in neutral and low speed, as well as on land at the house. When I increase the speed and begin to punch the trim button the tilt and trim does not work. Any thoughts. Thanks you.
RRitt
Re: Mercury tilt/trim 50 HP 2 Stroke Problem
does it drift down? If your raise it a little and then give it gas does it stay or slam down?
Randy Walker
It does not slam down. It doesn't seem to function at all when at increased rpm and in gear.
RRitt
If it goes up and down at the dock then your motor, relays, wiring, and switch are passing their basic test.
If it goes up and down all the way at dock then you have enough fluid.
If it doesn't drift down from tilt then your check valves are passing their basic test.
If it doesn't go down with throttle then your bypass and trim limit are passing their basic test.
not much left ....
maybe its a loose connection or bad relay and changing angle of boat is causing it to stop working.
Randy Walker
Thank you for the information, RRitt. I will double check all test you have mentioned. Good day for Texas, land of Possum Kingdom Lake, where the golden is killing again.
Randy Walker
That is good day from Texas and Possum Kingdom Lake, were the Golden Algae is killing the fish again.
RRitt
LOL. You mean there really is a place called Possum Lake? I thought Jethro and Granny were just making that up.
