Newbie here,
I've been fishing for over 20 years now but have always used someone elses boat/motor, I recently purchased a 82 - 14ft smokercraft with a 82 Johnson 25 hp Seahorse from an older woman who says its ran like a top for the last 26 years but she is too old and fragile for it now and it has sat for about a year and half. Although I'm new to the boating side I consider myself very mechanically inclined so I used this site and did some tuning up. Here is what I did
- Changed lower end oil ... water came out followed by oil (I'm assuming thats not a good thing?)
- Changed plugs ... Champions gapped to .30
- Cleaned prop and prop spindle
- greased all fittings
- new gas and oil mix to 50:1
hooked up earmuffs and lit her up ... took about 10-12 pulls with choke on full. Started with a high rev and died within 10 seconds. It would start then die... it would then run for a minute or so but at a really high rev even when turned the accelerator right down to slow. Also I notice the prop was turning while in idle, nothing fast or anything but it was turning. I'm tempted to bring it in to a mechanic that i'm sure would be more then happy to charge me a fortune, but I'm also a cheap pollack that thinks he can fix anything. Please someone help.
