fuel pump 120 looper
riverratfl
I am wanting to install new fuel pump on 1987 120 vro.Vro is not hooked up,looks like fuel pump and oil pump on same block.question is they want around 300.00 for that assy want just fuel pump.IS that possible and what is part number etc.thanks from sunny fl.
tashasdaddy
Re: fuel pump 120 looper
you can use this:
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
it is the old 3 line fuel pump, pulse line from block, gas in and gas out. you will have to find a mounting point.
SparkieBoat
heres a link for a rebuild kit for the fuel side of your VRO pump.
