Islandlure
- May 14, 2006
- 63
Hi guys, wondering if someone can point me into the right direction with this. I have an 85 115 V4 Evinrude on my 17' Roberts flats boat. I just swapped this old motor for my old 85 Johnson 70 HP that was on it so I don't know too much about this new one. The issue I am having is a few things:
When I throttle up out of the hole it takes about a minute for the boat to come up on plane. It is not reving hard, in fact I can push the throttle handle to WOT and nothing happens, it just takes that long for the engine to catch up? I dont know what that is?
Now, once it does get up on plane I can hold it about half throttle and seems to run ok but will start lurching on me and the really starts to miss after about a minute or so but I can make minor movements in the throttle and keep it going. As soon as I throttle up more she really starts to move, sounds good, no missing, then 10 seconds later everything just stops and the boat sits back down into the water. The motor doesn't stall out just comes down to an idle.
When the motor is in neutral I can rev it and hold it there with no missing, it just sounds strong and smooth, but as soon as it goes in gear I have these issues.
Here is what I have done so far:
1) New gas in tank. (Gas was fine on the 70HP anyways just a couple days before)
2) Took the carbs off and cleaned them out, they looked good, no varnish or build up.
3) Replaced plugs and coils and cleaned the mounts where the coils ground to the motor.
4) Fully charged battery. (not sure if this even matters but I did it because it was in the garage.
I don't know if this might help but my tachometer that worked on my 70HP is now only working up to about 2500 RPM's on this Evinrude then it just drops to 0. I did keep all the same controls as I had with the 70HP Johnson and everything just plugged in and matched up but i am not sure if there might be an issue here?
So if anyone has an idea where i should start testing or looking I would appreciate any insight! Thanks!
