bowman316
- Oct 21, 2008
- 1,822
I have a 26 ft sailboat, and the sink in the galley drains straight down, thru the hull, and the fitting is below the waterline. But the sink is above the water line.
So would sea water come in thru the fitting, up to the waterline? and anytime i add water to the drain, that will push sea water out to make the water level in the pipe even again with the sea level?
imagine a straw half way under water.
the boat is not in the water yet, so i just want to make sure i don't need any new thru hull fittings before i launch it.
also, the head intake and output are below the waterline too. is all of the standard practice, to put them all below the waterline?
