Hi,
I replaced gear lube in the outdrive unit (1993 Mercruiser) and tried to put back the vent screw (one on the left side). The manual said ?torque to 40 lb. ft.? I set the click wrench to 20 lb. ft. to be safe and, guess what, I broke the thread!!!
I did not push much, it was probably damaged before me, I just finished it?
So, the screw is stuck. It rotates, but does not go out. In fact, it seats there quite tightly, but I understand this is only a matter of time ? it will leak and fall out one day.
I don?t believe I broke the lower unit and have to replace it ?
Imagine I will get the screw out somehow, what can I do then to repair?
Can I simply glue the screw into the vent hole (and use the dipstick hole to vent in the future)? What kind of glue? Epoxy? Or, can I put another screw through the hole and put a nut on it from the inside (permanently)?
Thanks for your feedback.
