All: I have an issue with my Yamaha fuel management gauge, any help would be appreciated.
Problem: 2001, twin 200 HPDIs with original Yamaha multifunction gauges; Fuel mgt. gauge comes on fine when I turn the key, everything comes on, TTL, Econ, Sync, PS ect., showing the system check is fine. Now, when I crank the engines it may or may not show GPH & Total fuel burned, or it may start showing it, then 10 miles into the trip it stops. I bought the rig used in 04' and it has never shown the MPG or the Port / Stbd. icons while running. Is this optional? According to the manual if it is showing GPH, is should show everything else. So does it sound like the gauge itself, or one or both of the sending units? Is there a way I can test the gauge or sending unit? I hate to replace things that are not broken. Side note, the GPH & Total fuel burned worked fine until recently.
