Johnson 15hp 2001 wont crank
SEAL7
i had my boat on water last week, it cranked, turned over, then we ran it then shut it off. We cranked it again, it did for awhile then just started making a click im guessing in the solinoid. Does anyone know what is wrong?
the battery is fine and im pretty sure i checked all of the fuses.My yamaha 90 cranks right up with the same battery. Thanks, Evan
1946Zephyr
Re: Johnson 15hp 2001 wont crank
You may need to check all your connections on you 15hp. Make sure they are clean of corrosion.
If your battery cranks your big motor fine, then it should definately crank the little one.:D
SEAL7
Also, there is a rope start, one of those pull thingys, the rope wont pull out at all. Thanks again, Evan
kenmyfam
Does not sound very promising. Is it in neutral ??
SEAL7
thanks all for the help, the thingy looked like it was in neutral but really wasnt, that engine likes messin with me, jerk, i like my big one better,
Thanks again, Evan
kenmyfam
Thanks again, Evan
Rule of thumb. Check the simple things first. It can save you a fortune.
Glad all is now well.
