I am replacing the impeller and housing on my old Evinrude fisherman (5.5 HP) and am using a new re-manufactured housing and impeller.
The kit only comes with (1) gasket for the housing and my Clymer manual says there should be one on each side of the wear plate.
My mechanic told me when I bought the kit that I only needed a gasket on the upper side of the wear plate next to the impeller, but I'm wondering about the side of the housing that fits against the bearing plate. Should I get another one or just use some form-a-gasket for that side?
Also, the manual recommends gluing in the new tube grommet with Scotch Grip Rubber Adhesive 1300. Can anyone recommend a substitute for this?
I have a 3M silicone adhesive that's supposed to be excellent gasket adhesive but not spec'ed for under the water line. Permatex form-a-gasket?
I also have gasket sealing compound?
Thanks for your input.
