twin 4.3 merc's 1good 1evil
Shawn48
Ihave a1986 searay 270 amberjack with twin 4.3's The port side engine is down rpms its had new plugs ,wires and rebuilt the carb also a commpression check. all good,but still hasent fixed the issue engine will not get to over 3800rpm HELP thanks
Re: twin 4.3 merc's 1good 1evil
Ayuh,... Change the Fuel Filters....
Aviator5
If that is new for you boat, then check outdrive gear ratio.
Shawn48
fuel filter/water sep has been changed.haxe had boat 2 years dont think outdrive ratio is diff from starboard side thanks
