Had a quick question regarding the ignition timing of a volvo penta AQ130 engine. My repair manual tells me an AQ130c engine requires 8 degrees BTDC and an AQ130d requires 12 degrees BTDC or the other way around, don't have the book with me.
The issue is I am using a AQ130d engine block with a distributor and head off a AQ130c engine. Is the timing I should use based on the camshaft, distributor or engine block? I would think it would be based on the camshaft, but wouldn't be the first time I would be wrong. Any help would be great.
