I am wanting to switch from my 3 blade AL prop to a 4 blade AL prop for better holeshot while doing watersports. Maybe to a Solas Amita 4 AL Prop in a 14X21 Pitch. Can someone run the numbers below for me and tell me if it should be a good fit. Will usaually have about the same people as below on the boat. We will be skiing, tubing, and wakeboarding. Two of the skiier/wakeboardes are 250/260lbs guys... so will need some gitty-up to get them up on the skis/boards in deep water starts.
Boat: 2008 Stingray 195LX (20 hrs on boat and motor)
Length 19'6", Beam 91", Weight 2580lbs.
Z-Plane Hull Design
850lbs of People/ Gear,
35gal. Fuel Tank (3/4 Full)
Smart Tabs
Transom Angle: 15?
Deadrise Angle: 19?
Motor/Drive: 2008 Volvo Pinta 4.3GL/SX V6 Carbed 190HP
Full Throttle Operating Range: 4200-4600RPM
Max Engine Speed, RPM: 4600
Gear Ratio: 1.79
Prop: 14"x23" Aluminum 3 blade Part# 48-832834A45
WOT RPM- 4350
WOT GPS MPH- 51.5
Thanks!
Z-Plane Hull Design
Smart Tabs
Transom Angle: 15?
Deadrise Angle: 19?
Gear Ratio: 1.79
WOT RPM- 4350
WOT GPS MPH- 51.5
Thanks!
