Hello and Thanks in advance to all for any leads you may be able to offer.
Problem - Disassembled control box to remove / repair shorted trim switch wires inside and missed something in the disassembly process because I am unable to get controls to work properly now.
Controls are Merc OEM and from a 1991 Glasstream with a Alpha 1 GEN II.
No pic available at this time but working on it.
Discription - Single lever Throttle, Trim up / down switch on top inside, Square Trailer switch just below trim, Square neutral throttle only button center bottom at pivot point.
In need of a manual and or diagram for reassembly if anyone can point me in that direction PLEASE.
NOTE: It was all working fine before disassembly except for the trim short which was blowing fueses, I found and removed the bad section (What fun that was). It all fits together fine but wont shift now, I put a connector or something in wrong position and am stumped HELP HELP HELP !!
Thanks
Thanks
