fuel problem
flyers
I have a fuel problem with my 1973 7.5 hp carb. Its starts up 1 pull idles fine and cuts out at half throttle wants to stall. If you pull the choke half way out it runs fine and will run wide open. I cleaned rebuilt carb numerous times , set float, replaced fuel pump diaphram and all gaskets along with new needle valve. good prime and vented. Anyone have an idea?
Jacket4life
Re: fuel problem
Not saying I'm an expert, but starting to sound more like an electrical problem. Coil, plugs, wires, etc. There are plenty on here that know more than me, but that's my 2 cents based on your description. Doesn't sound like there is any more you can do to the fuel side, and the old saying is: when you've eliminated the possible, what's left, however improbable, must be the answer.
flyers
Re: fuel problem
I replaced coils and plugs not long ago. I still think its something with fuel because of the choke helping it run better. thanks for reply though
mike1245
Re: fuel problem
i have gotten bad rebuild kits for pumps before they are cheap enough and easy enough so id try that agian and replace all pump gaskets and diaphram
Jacket4life
Re: fuel problem
Ahhhh, missed that on my first read through. Sorry. There was a guy on here not long ago that had a propblem with the check valve in his fuel line causing similar symptoms. Not saying that is it, just throwing things out there for you. I'm sure you've tried the old squeeze the bulb trick when it does this, instead of pulling the choke? I know you replaced the fuel pump diaphram, but that is the check for fuel pump probs.
flyers
Re: fuel problem
I actually just replaced the fuel pump and diaphram gaskets this morning and no change. Also pressing the bulb does not help it at all just choking it does.
Jacket4life
Re: fuel problem
Well, you've passed up my expertise. Hope someone else on here can help!
Best of luck!
achris
More fish than mountain goat
Re: fuel problem
Sounds like you still have some dirt in the progression holes of the carb, or the idle mixture screw needs to come out 1/8 to 1/4 turn...
Chris......
flyers
Re: fuel problem
I made some adjustments with the mixture screw but didn't help. I guess I'll pull carb off again and check it.
