So I just got my boat back from the mechanic who charged 520 dollars and gave me back my boat in the same condition it was before I brought it in. He repaired a reed gasket and changed spark plugs. Great mechanic huh. Then he tells me the motor needs a powerpack. So I replaced the powerpack and it did not help. SO heres the deal. We noticed when we squeeze the primer bulb a little bit of gas dribbles out the top of the VRO. Also the plastic nipple was broke and JB welded on the VRO where the gas hose connects. So on the water the motor started and idled ok and i went to take off and it ran ok and got on a plane but didnt go as fast as usual. I had full throttle and was goin maybe 25 when usually go 43mph. So it ran like this for bout 30 seconds and then bam it bogged down and killed. Then ran like crap and I barely got back to the launch. It would start and kill in idle. Sometimes I would get it to idle then put in gear and it would kill. I noticed if I put it in gear and got it to run when I pushed the key in for choke it would try to take off. Then I noticed at the boat launch while idling I could hear a tick tick tick sound from the cylinders. Sounded like metal on metal like a rod. Didnt sound good. Is this a sign that the vro is suckin air?? Im tired of throwing money away at the motor, but it used to run perfect before all this trouble. Thanks for any replies.
