I'm really looking for another troubleshooting "tip" on this one. I've been "cleaning up" a '95 Evinrude which I got in the deal with a trailer (was essentially free). I decided to clean it up a bit - although it didn't need it (start of thread here). Anyway, I got it all back together and did a final paint job:
and install:
I ran it on the hose and it started right up and purred (very smooth with 3 cylinder vs my '83 which is a 2). So, anyway, I took it out for a run and after getting out the channel and hitting the gas, it just sputtered to life... I couldn't do much more than about 5 knots.
I've been searching through threads since the weekend and my conditions seemed most similar to this thread. So, I removed the carbs again (I had rebuilt them). I re-adjusted the floats. I should admit that I don't have the special OMC tool (on my '83 - I always made sure the float was perpendicular to the body). Anyway, I adjusted all floats to 1 and 1/2" drop as specified in the service manual. Put the whole thing back together and took it out for a run today. Same problem. I pumped the fuel line bulb and didn't get any increase in RPM. I'm convinced it must be a "high speed" jet or float issue as it absolutely purrs at idle and it's getting spark. I stared through the powerpack testing in the manual - and so far all the resistances are fine. It just runs too smooth to be a spark issue (it seems). I made a tool for pulling the high-speed jets and did so and cleaned with compressed air...
I'm worried maybe I botched one of the carb rebuilds (although I did them sequentially). I've cleaned my older motor's carbs numerous times over the years...
Any ideas of other things to try are greatly welcomed (and appreciated)!
and install:
