Tryin2Boat
- May 12, 2010
- 3
New to boating all together fellas so take it easy on me. lol. I have an 86' Sea Ray 21'ter B/R with the original Mercruiser 230 which I'm told is basicly a Chevy 350. The engine isn't locked up as I've turned it with a breakerbar on the main crank pulley. I've tried to start it but all I get is a resounding "click" from the circuit breaker. I've also run a direct line from the Positive terminal on the battery to the Positive terminal on the starter with no response. So I'm going to pull the starter and have it checked as it probably needs to be replaced anyhow. In any sense I'm sure I'll get it running as it should soon. Seeing that my project boat is turning out to be much more intense than I anticipated, I'm seriously thinking of just pulling the I/O after its running and putting it in a one of a couple of boats I've found locally that are inexpensive and just need power plants and drives. My question is can what I have fit in a newer boat that was fitted with different equipment? For instance, there is a 1990 19'8 VIP Victory B/R that had a Ford 5.0 with an OMC Cobra outdrive in it and there is a 1988 18' Checkmate B/R that had some kind of Mercruiser in it. They both have solid floors and interior in far better shape than my boat. What do you think would be the path of least resistance guys?
