Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I believe its a trolling motor of some kind but i have never seen one like it before. Also is all of these things for the motor? Can you guys tell me what all these things do?
You have a Neptune engine-mounted electric motor. It is designed to be mounted on the AV plate on an outboard or stern drive. The first picture is the motor speed control box. The third picture is a 12 volt and 24 volt charger and the picture on the far right is the motor. There should be another dial type speed selector piece.
Because it is called an on-board charger. No need to lug one back and forth between the dock and the house/cabin. Just plug it in. Besides, it is 12 volt AND 24 volt. Most portables are 12 volt only. Chances are this electric motor is 24 volts and therefore requires two batteries (big ones) wired in series.
