350 vs 350 magnum
bones774
I have a 350 magnum and it is listed as 270 hp, 10 more than a regular 350, the specs for both engines are the same including compression, i'm having a debate with a friend about the difference between engines, some say pistons, others say cranks, 2 bolt or 4 bolt main. anybody know for sure? thanks
Philster
Re: 350 vs 350 magnum
One of these: More precise fuel delivery (better MPI vs. EFI just one example) and/or better air flow intake and/or slightly less restrictive exhaust.
bones774
In my case it's a 1988 motor, carbed.
msojjo
I was actually wondering the same thing. From what i just read is it really just the fuel delivery? I have a 2000 350mag pushing out 300, or so it says. I need a new block on mine, and wanted to make sure that there wasn't a difference between internals on a regular 350, and a mag. Anymore help or comments on this matter would answer a few questions
John_S
It would be helpful to know if you mean: short block, long block, or just the block. and what you mean by a "regular 350" (the 250hp 2brl of same year?). You can find most of what you need in the same link mkast provided.
Philster
Jeeze, cleaner, more refined intake runners could be worth 10 HP. Doesn't take much, folks.
JES233
My 92 mag motor has a bowtie intake and a thermo-quad carb.I have never found any cam spec's
mkast
From Mercruiser #15:
SBC
Lobe Lift +or- .002 intake .263 or .287
exhaust .269 or .300
Duration @.050 intake 269 degrees or 296 degrees
exhaust 283 degrees or 307 degrees
BBC
Lobe Lift +or- .002 intake .300
exhaust .300
Duration @.050 intake 224 degrees
exhaust 224 degrees
Philster
Did I read that correctly? That compares cam specs on a Big Block vs Small Black, but the open 10-horsepower question is about a 350 versus 350 Mag.
45Auto
The intakes are different, everything else is the same, well except the stickers and the price.
Close, but no cigar.
The carbs are also jetted slightly different. Note the specs on the standard 350 outlined in red and the 350 Magnum outlined in blue. Different jets, metering rods, and hangers. From Mercruiser Manual #9, 1985-1988 GM V8's, page 5C-2:
180shabah
Sorry, yes the tuning is different, but all of the other hardware, crank, pistons, cam, heads, etc is the same.
Mkos1980
The hi-rise intake has a bowtie in front of the distributor. These intakes are gold with circle track racers. I find them at swap meets for 40 bucks and resell them for $100+ on eBay. The intake is on par with the Edelbrock RPM intakes. Not the low rise performers.
TilliamWe
Banned
The "famed" Z-28 intake is that good or bad? mines a 88 how can i tell?
Thanks
It's good. The bowtie as mentioned can tell them apart, but also as mentioned take a picture. The hi-rise manifold is physically taller where the carb mounts. Obvious to the eye, at least to many people's eyes.
bones774
Pic will have to wait, boat is at another location. Thnaks
