1993 Johnson 9.9HP no spark on top cylinder
shooter43
Tested both cylinders with spark testor. Have good spark on bottom cylinder. Exchanged plug wires, same results. Exchanged wires from power pack & problem moved to other cylinder. Changed power pack wires back & problem moved back to original cylinder. Regulator/rectifier seems to be okay. Not sure how to test stator(s). I figure if I changed power pack wires to coil (which I did) & the problem moved to other cylinder (plug wire), (which it did), then the coil must be okay. Right now it seems to be the power pack or stator(s). But, I'm not that good with small engines so any help/suggestions would be greatly appreciated. Thanks.
jmendoza
Re: 1993 Johnson 9.9HP no spark on top cylinder
Rick and others here would tell you it's a bad power pack, and I would tend to agree.
