Re: 2008 Master Craft X2 Wiring
You don't need one. If none of them work, check the fuse(s). If they are ok, check for 12 volts on the line side of the switch. If not present, determine why. Power comes from the fuse so if the fuse is good the problem is between the fuse and the switch. If there is 12 volts at the switch turn it on and check at the load side. If 12 volts is not present the switch is bad. If it is present the problem is between the switch and lights or the lights have lost their ground.
