tater76
- May 7, 2010
- 712
Ok, so i have had my 16ft tri-hull 1973 Chrysler 55hp combo out 4 times this year already with no issues until today. The motor started to studder and lose power after WOT for approx 2 mins. I immediately checked the carb, took it apart cleaned it, replaced needle seat, installed new plugs, this is when my heart sunk. Pulled upper plug and found no gap, that's right it was smashed into the electrode. I immediately thought wrong plug, too long right? wrong! looked at the plug and found little balls of ? imbedded between isolator and plug housing, and there was a dent on one side of the arm over the electrode. I figure I have a melted ring right? but to get to shore I stuck a new plug in and all was fine for a while. I had power back, and no rough idle, then after another few mins of running WOT it did it again! Same smashed arm on the plug, but still ran on one cylinder ok. Put new plug in again, and never had another issue. What the heck do I do? leave it be and run it, or pull the head and check for broken melted parts?
