gatorscott
- May 17, 2010
- 3
History, engine rebuilt over a year ago, carb rebuilt one year ago, replaced fuel line this weekend tested with fresh, ethanol free gas. Volvo penta 5.7, 1998.
Engine starts normally. Will run for 15 to 25 minutes and then stalls. Engine immediately restarts, no problem or issue. Engine will then stall again within a few minutes. Will immediately restart with no problem. Engine will stall again and restart with each subsequent stall ocurring in less and less period of time.
The engine does not backfire, just quiety stalls. A faint puff of light grey smoke exits exhaust near prop. Boat runs fine when up on plane and RPMs over 2500-3000. Seems to idle fine except for stalls. Never has an issue immediately restarting.
No water in gas. Have replaced fuel filter, fuel line, tested with fresh marine fuel, engine was rebuilt as was the 2 barrell holley 2300 carb. Carb was in bad shape, mechanic soaked it in acid for a day. Stalling still happens with fuel filler cap removed.
Boat has had this feature since then, so am assuming the carb is my problem. Fuel pumps seems to be fine as it pulled from the test container and fuel tank fine after changing the fuel line. How can I test or confirm? Could it be anything else? What am I missing?
I am by no means a mechanical guru. I can do some things myself, but don't know the innards or terminology of a carb, but am willing to learn.
