helpsvc.exe %#@&* grrrrrrr
Don S
What is this program, and why does it start when ever it wants to and uses 100% of the CPU for several minutes and I can not control it.
I have looked it up on Google, but still not sure what is true or false or what can/should be done about it.
Windows XP home.
NelsonQ
Re: helpsvc.exe %#@&* grrrrrrr
Don
The helpsvc.exe is a core program file for Windows and is used as its name implies, Help Services. (Under Start Menu, if you run Help and Support) it will run two programs, helpctr.exe and helpsvc.exe and normally doesn't run after a restart unless you've run the above program.
So two immediate reasons come to mind.
1. Virus....very possible. Hopefully you have a real time virus scanner, and if not, you should get one, scan your system.
2. Latest Service Packs/Hotfixes for XP installed? There was a known issue that was addressed for XP assuming you're all up to date. If not, install the latest Service Packs/Updates from Windows
Another quick check for #1. Look in the C:\Windows directory.
Check the size of the file HELPSVC.EXE
Should be one of these
743,936 bytes (71% of all occurrence)
703,488 bytes
696,832 bytes
744,448 bytes
694,272 bytes
Sizes vary depending on patch levels/version of XP running.
Hope this helps.
Don S
Just to give you some idea of how my evening is going.
1. Can't even find C:\Windows directory or even C:\Windows
2. I have Norton AV and have had it for years. Don't like it but can't seem to get rid of either.
3. All MS/Xp updates are automatic and have been for years.
4. I Never use MS Help, but this exe file starts on it's own at least daily. That I am aware of. Usually in the mornings when I first get online.
5. Please don't tell me to get a manual, I have one, it came with the computer. That is the worst piece of gibberish (sp) I have ever tried to read. It's nothing more than nonsensical words strung in random order to closely resemble a sentence.
6. Time to get a cold beer, and watch Star Trek for a while
TahoeQ4Pilot
[snip]
Uh, sometimes it's just better to get a helper cause....by #1 alone I suggest you are not going to be able to successfully figure this one out on your own.
Know any 20 year old college kids? :D
dolluper
Right click on the bottom of the screen in an empty space and pull up your task manager ...once in task manager click on helpsvc and then hit end process
Tig
Have Scotty run a level three diagnostic. :)
Lots of good thoughts here already.
Tell us a bit about your PC.
CPU speed (roughly, to judge age)
How much memory?
I have seen low memory cause the CPU to become consumed in paging to disk and bring the machine to it's knees. helpsvc misbehaving may be the task that puts it over the edge. How busy is the disk during the bog?
Summer Fun
Banned
Don, Go into Control panel and then Administrative tools and then Services
Its under Help and Support in there.
Then find helpsvc and disable it for good so it doesn't start up automatically when you fire-up your compu. . :)
NO HE DOESN'T"T HAVE A VIRUS. !!!.
You people kill me when you don't know what something is. :eek:
Andy in NY
sometimes a virus can disguise itself as something else. not saying it is, but its a possibility. rarely should any program use 100% of the cpu.
