Starter Spins but wont engauge
Status
Not open for further replies.
Ahole
mercruiser 4.3, Starter spins had but gear doesnt throw into the flywheel. Had starter rebuilt, new slave solenoid, new battery. Does the samething as it did when I started this project. The starter was bench tested after rebuild. It spun and engauged. Im certain its hooked up right, tight, all teeth on flywheel. why does it engauge on a bench test but not on boat? Now what?:confused::confused:
RL Gman
Re: Starter Spins but wont engauge
Did the bench test put the starter under load? Or did it just test to see if it would spin and engage w/o load?
W/o load on the starter, it isnt much of a test...probably just need a new starter, or re-build again.
Fishermark
Are you sure it doesn't throw into the flywheel? I ask because it sounds more like a bad bendix to me. If the starter spins and not the engine - at a high rpm - then the chances are good the bendix is bad. That wouldn't show on a bench test.
Ahole
wasnt under a load. I talked to the guy that rebuilt it, he said it looked brand new inside as well as the rest of engine componets. He said he replaced something in it but i forget what he said. I am charging the battery now though its close to being a full full charge. I read though some posts on here with pretty much same issue. Hopefully it works. I took rest of week off to get it ready for the holiday
RL Gman
Yeah, if the battery was charged when you tested, and it didnt engage, it's still your starter...
Ahole
just checked, battery showing 16 volts..Im thinking thats more than enough. you thing I coulda bolted starter on backwards? Is that even possible? It was off when I bought the boat so I didnt see how it came off.
RL Gman
I'd have a hard time believing you bolted the starter on backwards...and no, I dont think thats possible. But..the gears should be facing the flywheel...I guess you could check that :confused:
My guess is still that it's a bad starter.
Ahole
All the shops are atleast 2 weeks out. I think I might just buy a new starter
Fishermark
Yep.
As long as you are sure the flywheel is not damaged, then your starter is bad.
robert graham
Are you sure you've got your battery cables hooked up right? If they're reversed it can cause the starter to turn backwards.
Ahole
I have the Batt cable, hot to the boat and orange wire on a post. nothing on the other large post. Purple on left and yellow on right. the big red one is on the + side of batt. Sometime u have to shim a starter on car..same on boat?
Colliemcc
you have a good earth? i had problems like that before and it was a bad earth from bat to the block.
coquitec
Hello there i am a girl i have the same problem i change the starter for a new one the first 2 cranks seems work , but now the same problem just spining ?? Any help please !!!
GLENN M
when you say just spinning does it make a lot of noise or just spin,if its grinding it needs to be shimmed,are these chevs,if so take main power off starter and then put power to start on solinod it should kick out bendixs,my guess needs shimming.
coquitec
my starter after the last one which would spin and then grind and take forever before actually getting the boat to start. I inspected the flywheel and while there were some chips I didn?t see any major damage such as missing teeth. After getting the new one all set up I connected the power and it seemed to engage the flywheel just as it should. I brought my boat out, connected the muffs, and tried starting again. The first few attempts seemed good but on my last try it seemed to bind a bit. Now when I turn my ignition the starter just spins and it seems the bendix isn?t popping out to engage the flywheel.
I am going to pull the starter again to inspect it but does anyone have any clue why a new starter would all the sudden just spin and not engage they flywheel?
Thanks!
ShadowB
You might want to try shimming the mount bolts. Over time the surfaces wear and the starter will sag a bit. That little difference will change the engagement angle. Should be able to get them at any parts store for a couple of bucks.
Don S
Welcome to iboats coquitec,
Please do not hijack someone elses post to ask your question on, if you have a problem, start a new thread with all your information, then you will at least know if someone is answering your question or the original posters question.
Status
