we adjusted the points
Welcome aboard!
If this is the first time you are trying to start it after a long lay up, the chances are good it is your points. Especially since it is not doing anything with the "engine start spray." (By the way, you need to do away with that product - it will do more harm than good and should never be needed).
I suggest simply replacing the points. Not adjusting them.
You can try filing them first... but you will need to replace them anyway. Good luck!
If it just clicks then u have a low battery, bad connections to the starter or battery, or the starter is shot. Charge the battery & check the above connections. If it still just clicks, then u probably have a bad starter. By the way, do the accesories such as bilge blower, lights, etc. work?
