titleistprov21
- Apr 30, 2010
- 9
Hi Guys,
My 90hp Merc Force outboard is very tempermental when I try to start it. This saturday, I flooded the engine pretty good - and I got her started about an hour later. When I shut off the engine on saturday, I disconnected to gas line and let it run out of gas.
When I started it up on Sunday, I re-connected the gas line, gave it a couple manual hand pumps to get fuel into the engine, tried starting once with no choke, didn't turn over, then once with choke and it fired right up.
After having the motor off and hanging out on the river bank, I just tried to start it up with no choke and it has a hard time turning over. Which causes me to go into freak-out mode and give it choke, then throttle only, causing it to flood. I eventually got it started after about 6 or 7 tries.
Can you guys please give me some advice on how to start it up without giving me a heart attack thinking it won't start. Do you think I need to clean my carb?
Thanks in advance for the help!
