Hello, I have a 1959 10hp Johnson. I believe its a QD-20. I have replaced the coils, impeller, and spark plugs and done a fuel pump conversion and I have gotten it running. Now I just have a few kinks I am trying to work out.
1) The motor kicks every 5 seconds or so when its running.
2) I have messed with the carb settings and set the low speed needle as rich as possible but the motor still stalls out if I lower the throttle to try and shift gears.
3) When I pull the cord to start up the motor it turns the section under the flywheel which turns controls the throttle. Basically you need someone to hold the throttle in place when you pull the cord.
If anyone has any ideas on what could be causing these problems please let me know! I was thinking maybe the new coils are rubbing or something to cause the cord and kicking problem, but I really have no idea.
