Hi!
I have recently purchased a 1996 Larson, and it seems to have a small problem. I have been reading through posts and the Adults Only section, and based on what I've read I'm wondering if it might be a carb/fuel system problem.
The boat starts right up and idle sounds fine. When moving the throttle slowly through the throttle range it backfires a bit in the middle of the range, but comes right out of it; the same happens when reducing the throttle. Optimum rpm at WOT should be around 4600 RPMs, however the first time I had it out it was maxing out at 2800. There is a 14.5x19 prop currently installed and I was also given a new 15x17. I know that changing the prop would help somewhat, but not 1800 RPMs.
The second time I had it out I found that if I pulled back the throttle about an inch or so from full the RPMs increased and the engine sounded much better. Doing this allowed me to get the RPMs up to 3600 or so with some fluctuation, so maybe a carb problem or the linkage is out of adjustment??
On my third outing, I checked my speed with a GPS and at full throttle was right around 15mph and RPMs were still low. At one point I was able to get it up to 19mph and it held there until I backed off, and then I couldn't get it back. I don't know if I had it trimmed just right when I hit 19mph or if the moons were just all aligned, but I believe it should be capable of going a bit faster.
The previous owners were an elderly couple that did not want the speed and purchased a pontoon boat to replace it. They did not use the boat much last year. I'm just wondering where the speed is that they didn't want?
Looking forward to your responses!.. Thanks in advance!
