wintremute
- May 20, 2010
- 2
Hello folks,
Long time lurker here but first time poster... please forgive my ignorance
I'm sure I am always in the wrong forum...
I have recently purchased a 1990 (Sun)Tracker Bass Buggy 18ft'er w/ the original 40hp Johnson. I am familiar with the ol' boating world, however it has been 15+ years since I have owned a boat and that was a 60's 14ft runabout my buddies and I rebuilt in high school... a lonng lonngggg time ago
So I guess I will get right to it and see where is leads me.
1. I can not lift the motor to tilt it up. It looks like there is a 'tilt assist' cylinder there but it may be frozen up or bolted off. This is a used boat ya know! How can I bypass/overcome this? Links to manuals would work wonders here.
2. I have done a poor-man's tune up (plugs, fluids, cleaned the carbs) but it still seems that it is idling on only one cylinder most of the time. a lot of coughing every 10th or 12th cycle it seems. Worse on muffs, but also in the water. Seems to be ok at 2500+rmps in the water. Maybe that's normal?
3. The primer doesn't seem to work off of the key switch. Push to choke....nothing. Have to flip the red switch and prime it manually before we launch. Bad primer pump?
4. The trim tab on the bottom of the lower unit is missing and it's pulling to the right pretty hard. Does anyone have a source for replacement parts? It's a a TJ40 ELESR model. I have looked through the links here and determined that this means it's a 40 HP Johnson, made for Tracker, electric start, remote, made in 1990. Right?
5. My prop is pretty beaten up and I would like to know the best options for a replacement one. 3 blade? 4 Blade? pitch? So far, with the motor trimmed WAY down (too low already) I can hit 17mph@4800-ish rmp via GPS. I don't know where the power band is on this motor, but the tach says redline is 6000. I'm not expecting to pull skiers with a 40HP motor, but it feels a bit over loaded at the moment. 20mph or more would be great.
OK guys I've laid it all out there for ya. Let me know what you think!
