Re: stalling when in water 50hp 1996
this is a common phenomenon. When the lower unit is submerged, there is backpressure on the underwater exhaust. On the muffs, the engine is completely unloaded, it'll idle on one cylinder. You can't really judge how well it's running till you put it in the water.
Been like this since you got it, or it was running fine up till now?
What recent maintenance has been done to this motor?
Any other symptoms? Cold start, warm start ok?
Fuel line holding pressure? Tank vent open and clear?
Premix or VRO?
Back to basics...compression test, then a spark test. Use an inline spark tester, gap set to 7/16", clipped to the engine block. Attach the plug leads (one at a time) and look for a good strong spark while cranking. Do this with both plugs removed and ground the floating lead while you test the other one.
report your results.
welcome to iboats.
