TN27 Help what spark plug?
440racer
I'm working on the old TN27 and think I should change the plugs.
Champions site only goes down to 1952 and I believe mine is a 1951.
Champion says J8C.
Somewhere else here on Iboats I think I saw J6C.
I don't think there's much difference but thought I would try to determine the correct plug.
Any ideas?
Vic.S
Re: TN27 Help what spark plug?
TN 27 is 1950/51 but the list we mostly refer to for plugs only goes back to 1954 for the 5 hp but give J6C for 1954. other models from the early 1950s also use J6C
J8C is hotter than J6C and I dont see it suggested for anything. All J4C or J6C.
I'd use J6C at 0.030"
440racer
Thanks Vic S.
THe J8C came from Champion's website but it only referenced 5 hp back to 54
I'm glad you replied. It may have been bad to run the 8 and run it too hot
seahorse5
The original sparkplug was a Champion J8J which is now the J8C
Vic.S
Revise my suggestion then. Make it J8C after all.
i could not find anyting with the original spec for a 50/51 model
cougar1985
check over on the aomci site in the ask a member forum.if your on the champion spark plug site i think your on it has many and i mean many wrong applications and may cause you grief if not lots of money in blow motors.
