140evinrude prob
green-horn
i have tried every thing from heat to having a buddy help move it wile i pump grease into it but it only sqeezes out the bottom of the pivot shaft or main steering bracket does any one have any ideas?
kenmyfam
Re: 140evinrude prob
Grease fitting does not lube the steering tube as far as I know. Penetrating oil and time to begin with. Multiple applications and do not be in a hurry. Massage gently in both directions. Get a little movement and you have almost won. You have to dissolve the hardened grease first.
There are a few other options but this is where to begin.
My 2 cents only though.
green-horn
i took the steering tube off and its fine the motor is stiff and ive been soaking it at the top of the pivot point with marvle and its not getting any better theres only one grease fitting
kenmyfam
Then pump some penetrating oil in there instead of grease. Time and dedication are the biggest factors here.
green-horn
is it posible to take the motor off and clean the area inside?
green-horn
i tried penetrating oil for all most a week now and its not getting any better does any1 have an idea what i can do??????
green-horn
yes but it takes some mussel and its really stiff and gets stuck
kenmyfam
Apply the lube, let it penetrate, move it a little each way. Apply the lube, let it penetrate, move it a little each way. Repeat over and over. Frustrating but unless there is a different issue going on you will get there eventually.
Good Luck and keep working it.
green-horn
does it matter what pasition the motor is in up or down?
