1969 Johnson 85 hp no fire....
85 BOMBER
Greetings everyone! I have recently aquired an 1969 Johnson 85 (85esl69s). I am not getting any spark to the plugs. I have checked for voltage going into the coil and coming out as well. That checked good. I am not getting anything coming out of the distributor cap, so I removed it. Upon inspection, I noticed 2 small hairline cracks on the underneath side of the cap between the brass terminals. I know this can cause it to "arc" or "jump fire", but shouldn't I still get something? The points are new, and have been set to specs. Is there a way to test the stator with a voa meter? Please advise, as the parts for this "oldie-but-goodie" are relatively expensive. Thanks in advance for all your help!!
mike1245
Re: 1969 Johnson 85 hp no fire....
disconect kill switch and see what happens (its the black wire with yellow stripe on the key switch)
85 BOMBER
Thanks Mike1245! I'll give it a shot and let you know how it turns out.
mike1245
what kind of shape is your stator in you can disconnect stator and try it agian
