Re: need help with proper vent routing for blower motor
It is really pretty simple.
Gas fumes are heaiver than air so they sink to the bottom of the blige.
So the exhaust hoses you you want as low in the bilge as possible without being so low that they could be covered by water.
They must be lower the any spark source on the engine.
One should have a bilge blower on it and a cowl faceing the stern. This one will be used with the bilge blower on before starting the engine. This is a good time to go back and siff the air for gas fumes.
The other should be the same except with no blower. This one will suck out more air than the one with the blower while driving down the road or running at speed out on the water.
On the other side you should normally have two more cowl faceing the Bow.
These are for air input. Many times these will have no hose on them.
Ideal is for them to have a hose to the engine area but higher than the Carburator.
It is the same Idea here to force the heaver than air gas fumes down to the bottom of the bilge where they will be sucked out.
By the way if you ever smell gas do not start the engine. Get everyone off the boat and then try and find the source of the smell.
I would suggest you take a Coast Guard Aux Boating Skills and SeamenShip class or a US Power Squadron class.
Both of these classes cover all the saftey gear in depth and well as rules of the road,
how to read charts, what the buoys mean, what sound signals you are required to give an what they mean, How to use VHF Marine radio for a Emergency or to contact the marine.
Classes are Cheap and fun and will make anyone who takes them a better boater even if you have been boating your entire life.
