glazedeyesvodka
- Jun 2, 2010
- 7
Was hoping there was someone out there who has had this problem or might know what it is. Motor will start and run fine at idle or in neutral, but when put under load at "wot" it hesitates like it is starving for fuel or ignition. It doesn't do this everytime you put the motor under strain,and sometimes it doesn't do it at all,but when it occurs it takes a good while for it to clear up. Both carbs and fuel system have been completely cleaned out and went through,new plugs,wires,fuel tanks,fuel filters,etc. Motor was running about 30-32mph at 5200rpm last summer and this year only 28-30mph at 4800rpm. Magnapower ignition was replaced in early 80's,but i can't seem to find many electrical parts or info for this particular year model# motor. I'm completely clueless as to what is causing this issue. Any and all help or suggestions would be greatly appreciated.
