Re: Jacked up Trailer and Outdrive of I/O Motor touched asphalt
SO, I took the day off to deal with this. Failure. JB Blaster does nothing to remove the star adjuster, neither does heat. the entire drum cover is rusted on. Hitting it with a hammer does nothing. Does not budge. Been at it since 7am.
Question: On the back are four bolts. If I remove those, will it just come off? and I will buy a new one. Do I need to remove the bearing cover and bearings first?
Regarding the master cylinder and brake fluid resovoir, the plastic cap that should be on top of the actuator is gone. there is just a rusty hole where fluid should be- had no idea when I bought the boat and trailer.
THANKS...
