250 OX66 Trim Problem
jlopvar
Port engine was not trimming up very well from down position. After unsuccessfully trying to assist engine up while activating up switch, saw a white foamy liquid leaking into the water from trim assembly area. Now engine wont move at all. Any help on diagnosis and fix? My original thought was low trim fluid but after seeing liquid seems I have a seal leak somewhere in the assembly...
As always thanks to all for your help.
rodbolt
Re: 250 OX66 Trim Problem
open the manual relief,raise the engine,trip the tilt locks,close the manual valve,fill with fluid, operate the unit and see whats leaking,fix the leak.
