aidan.calder
- Jun 3, 2010
- 5
Bit of a funny one my old dt60 has stopped stoping. in runs well and still throws my little 14" shakespear across the water like its prop is on fire but no matter what i do it wont stop so i have to choke it or disconnect the fuel line and let it run dry. I know that the red and blue wire is ment to kill the engine when grounded but this does nothing. I have stripped and cleaned all the bullet connectors and the CDI unit connector but all attempts have failed. A mate suggested that the CDI unit might be faulty or the ground has corroded but I dont understand if that is the case how the engine still runs as surly the coil packs wouldnt get a fire signal. Any help or suggestions would be appreciated as i dont fancy shelling out on a new unit if i dont have too.
