Hi guys, new here and new to glass boats. I owned a small 1236 tinboat and was on tinboats for a while planning to deck it, until I took it out on the lakes...not decking that thing. After my 3 year old threw his tackle in the lake, I decided to ditch the boat and buy what I really wanted (bigger boat) later. Well, later came 2 months instead of a few years as planned.
A gentlemen here in Jackson, TN was giving a Titan boat with a 75 hp Evinrude with tilt and trim, and a trailer for FREE. I told him I could afford that.
Yesterday I got it home and tore out the deck, seats, popped the powerhead cover to check the engine. I have a laundry list of things I know need done and no knowledge of how to do them.
- Steering cable is frozen
- Deck needs replaced
- Repainted?
- The hull needs reglassed or resined...don't know which or even if the terminology is right
- Inside the hull, i noticed the stringers are built in? one of them is partially gone, the hull flexes a little
- Transom is S-H-O-T
- Chalked and dirty, but I am dedicated to fixing her
Pictures:
If you look closely, you'll see vegetation growing in the boat...the deck was like compost and the veg was alive and well. An entire ecosystem existed in the boat. I have never seen so many ants in my life.
My questions, if you don't mind throwing your expertise at it:
- How do you rebuild the stringers? They were all of maybe 1 inch tall. Can I just add fir strips and glass them?
- How do you go about reglassing? Should I reglass or should I just repair the handful of chips and fair it out?
- Do I need to resin the transom? If you look at the second picture, the transom has a cap that comes off and it lifts out, more like it crumbles out ... lol.
- Really noob question: My flat bottom took a transom plug, do glass boats use transom plugs?
- When I do reglass or resin, will I benefit from glassing everything under and including the new deck?
- How in the world do you seperate the two halves? (top and bottom)
- Is it worth it? Should I scrap the boat and sell the trailer?
- Is it normal to want to fix up these poor pitiful boats? Most people shy away from these nightmares.
- I have fairly strong wood working skills. I have build an entertainment center for my home, so I am not shy around fast moving blades. I am scared to death of fiberglass. It itches and I don't like it.
- Can ants fish?
Thanks guys. I am excited to be a part of iboats.
As of now, I have removed as much as I can from the boat.
- Repainted?
Pictures:
- Can ants fish?
