'82 evinrude 70 hp
rledford84
motor idles well but shakes a little at idle but when throttle forward it will bog down and die.but if u work it till it goes all the way it only will run 5 mph.i have cleaned and re built the carbs changed gas.tryed to hit the choke when running but no difference.
mikesea
Re: '82 evinrude 70 hp
assuming you have spark on all cylinders (you did test right)make sure the timer base that is under the flywheel is rotating freely and along with the throttle arm that it should be attached to .Sometimes the plastic ball and socket break from age
Challenger84
I had the same problem with my 83' 70hp Johnson.
I cleaned the fuel filter and adjusted the carbs to allow more fuel.
As what Mikesea said check for spark.
You should also do a cylinder balance test, and compression test.
Worked out great for me!!
I was doing 15mph WOT runs when the motor was sick.
Now by myself I can get her to go up to 42mph!!
Hope that helps.
Goodluck
rledford84
pulled spark plug wire on cylinder 2 and there was no change in the way the motor ran
pulled spark plug wire on cylinder 3 and the motor died.
was gonna do a compression check but it started storming will do that tommorrow and post back.
SparkieBoat
you need a spark gap tester to test spark..should get a spark with a 7/16 gap.
AlanR
Yeah Compression Check... Im a little worried about cyclinder 2 if it has spark...
rledford84
checked compression it was 105 on all three cylinders
spark gap test was good
changed coil on #2 cylinder seemed to run better and was getting ready to head to the lake to try it out and noticed some chocalate colored looking liquid coming from lower unit and just got it back a week ago.so i'm going to take it back the mechanic tommorrow.then we will see
SparkieBoat
it is normal to get some oil residue dripping from exhaust, from unburnt oil/fuel.
check your prop shaft seal behind the prop and see..also check to see if you have any water in your gear case.
