Augoose
- Mar 21, 2010
- 1,245
I've got a 1989 4.3 mercruiser w/ Alpha I. The problem I'm having is a battery drain issue which started several weeks ago. After just a few days, the battery was completely dead (0 volts on both multimeter + dash voltmeter gauge). I thought I had found the problem (float switch), but today after letting the boat sit for about 2 weeks, the battery is dead once again (dash voltmeter gauge read at about 9 volts). For the heck of it, I tried to start it anyway but all I got was a click.
I then pulled the battery off the boat and headed home to hook it up to my trickle charger. When I got there and hooked it up, the charger immediately gave the "charged" light indicator. I checked it with a voltmeter (charger disconnected) and sure enough - 12.1 volts on the battery.
I didn't bother driving back to put it back in the boat and test it, but it sure made me confused. The only other thing to add is that this is a 6 week old Interstate Starting battery that, through the course of having to figure out this drain issue, has been drained completely to 0 volts twice, and drained to below 10v once.
Could this battery be damaged in such a way that it could show 12 volts with a meter but not have enough cranking amps to start?
If the battery is good, is there anything in the boat's electrical system that could cause the system to "think" there is only 9v when there is really 12v? Starter solenoid, etc? The battery is new, the cables are new, and as of two weeks ago, the boat was starting and running normally.
Thanks!
Thanks!
