1977 Johnson 85 hp 85el77s question?
Status
Not open for further replies.
GLPmike
Hello,
I have the chance to upgrade my older 1968 Johnson 65 hp with a 1977 Johnson 85 hp for my older Glastron.
The 85 hp runs strong, but the power tilt is broken. Question: is this upgrade worth the trouble of changing out motors? The 85 hp also contains a new OMC control box and wire harness. All four coils have Bern replaced as well as the carbs rebuilt.
Also, I did quite a bit of work on the older motor will things get easier with this one?
How about gas usage? Is the newer motor more efficent or the same.
Thanks
mike
ezeke
Re: 1977 Johnson 85 hp 85el77s question?
It's not the best choice. You would be way ahead if you wait for a 1979 or newer.
Replacements for the PT&T are not available and the gearcase, engine and ignition system are a dead end in 1977. 1978 is a one year engine model, so that's not so good either.
GLPmike
Deadend? Meaning if it has a problem in these area it's junk?
Getting the whole setup for $100.
I am not crazy about the 1968, so I thought it might be worthwhile plus pick up some additional hp....
ezeke
Deadend? Meaning if it has a problem in these area it's junk?............
No, it means that after that year just about everything changed on the V4 motors except the cowling and the spark plugs.
You will not have a problem finding most parts.
GLPmike
Thanks.
So, for a $100 investment it's a good move... This motor does not have unique problems, it's just that it's design was not used for the long term.
Will this motor be long enough fir a 20" transom?
emdsapmgr
There are a lot of improvements from the 68 to the 77. The midsection is quieter. It has the more modern crossflow two-barrel carbs which are easily worked on. It has the newer thru-hub exhaust for performance and noise reduction. You can put a wide variety of props on this engine. The ignition is a breakerless solid state type which is more reliable. The four individual coils provide a hot spark to each plug. The 85 was not particularly efficient, but I'll venture that it will burn about what the 65 does. There were many thousands of these 77 engines produced and many are still running. It is fairly easy to find basic parts, either new or used if you need to repair it. I'd go with the 77 and not even look back.
McGR
I recently sold my old rig with a '76 85hp (same as '77) which I ran for the last six years. I thought it was a great motor. It performed very well for me and was easy to work on. Parts weren't a problem either. If the price is right, I'd say go for it.
GLPmike
Thanks for the response!
F_R
I was an Evinrude dealer mechanic in 1977. The 85hp was one of our best sellers.
GLPmike
Would anyone know if the decals are availabe for this motor. I will need to repaint the cowling/cover as the prior owner painted it solid black.
Thanks
GLPmike
Thanks F.R.
Would you happen to know if this motor would perform well on my boat which has a 20" transom?
I believe transom's are either 20" or 25" and the short and long shaft motors are made to fit respectively. I also believe the cavitation plate should be equal to the bottom of the hull plus/minus 1-2 inches.
Are these correct assumptions?
Thanks
ezmobee
I used these http://cgi.ebay.com/ebaymotors/John...at_Parts_Accessories_Gear&hash=item335aa8a7ce to do this:
F_R
Thanks F.R.
Thanks
85E"L" is a 20" shaft. Should work just fine for you. The mounting brackets allow raising the motor, but not lowering it. The trick for best performance is to run it as high as you can without excessive or annoying cavitation or ventilation. Most of them sat down on the transom.
They didn't have 25" motors back then.
GLPmike
Could someone please tell me the correct fuel mixture for this motor?
Thanks
Ucee
GLPMike,
that engine is a great engine I had one as well But the impeller relacement was a bit tricky for me seeing how I never changed one before, but the mixture of fuel and oil is one pint of oil to 6 gallons of fuel. make sure your prop is in good shape and dont use full throttle like I did or your fuel wont last very long I went through 12 gallons in less than 1 hour running wide open lol family was mad at me lol... justsome helpful tips for you.
GLPmike
Thanks...
12 gallons in one hour at full throttle? Is that normal usage for this motor?
GLPmike
Ezeke thaks for the link....
I purchased all the manuals for my 68' 65 hp and they were a big help.
I changed out the WP, gear case, and ignition system for my 68' so am I looking at something more complex with this motor for similar repairs?
Thanks
ezeke
Most two stroke carbureted outboards will run 10% of their horsepower in gallons per hour at WOT. You can cut that in half by running at a reasonable cruising speed.
You can do better with DFI.
Status
