Xr2 150 blackmax
BUSTER101
I recently blew my xr2 150 got another used one from a dealer now takes forever to come to plane runs good after that. Had a 27 pitch on it put a 23 pitch on it helped very little what could kill the power from start had carbs rebuilt fluel system on leaks holds press good spits and sputer at idle as well
j_martin
Re: Xr2 150 blackmax
Try disconnecting the advance module, and do a complete link n sync except set your wot timing to 23 degrees instead of 19.
hope it helps
John
Faztbullet
What type of boat, as there are very very few 150's 2.0 liters that will pull a 27p prop
BUSTER101
It is on a stratos 279fs 16ft it came out the hole ok befor but now takes 100 yards or bettter even with 23pitch that is on it now
BUSTER101
Thanks set it sounds much better havent got to take it out yet but have a good feeling bout it will let u know after i try it out thanks again
