how to test powerpack
rhighfil
60 HP 96 Tracker Marine outboard ran great on Sunday.
When I tried to start it on Monday, it turns over but no sign of firing.
I checked the kill switch to make sure that it hadn't accidentally been tripped. It's in the right position.
I put in starter fluid (WD40) into one of the cylinders, nothing.
I don't have a spark checker but I did hold the plug against the frame while cranking and I can't see a spark but I'm not going to grab hold of it to see if my eyes are bad. I don't know what to check to make sure the power pack is getting electricity. Can someone help me with that?
porker99
Re: how to test powerpack
well the only way to test the power pack is to take the boat in to a shop and have the tested it probably it cost 35 to do the test
rhighfil
With the ignition on, I tested all the leads to the powerpack. None had power. Is that correct? The current wait time on taking the boat in is 3 weeks to a month.
