Re: motor jumps up in reverse
thanks for replies. apparently there is a lock on the mercury itself that was in open position, i guess if you are in area with stumps,etc it allows prop to not get damaged. I'm an idiot and the guy that installed the power trim just flipped the switch to lock and it works fine. guess it would have helped if i had the mercury owners manual. i may have caught it. i ran the boat 3 times with the switch unlocked prior to having the trim installed and don't remember the motor coming up out of the water like that, in reverse.
