Mercury 60 - Torque Spec's
BassnKY
I have a 1984 Mercury 60 S/N 6429362
I am trying to install the exhaust port cover, intake transfer cover, and cylinder block cover (Over the cylinder heads. It covers the water jacket at the spark plugs).
I have searched the Seloc manual and cannot find the torque spec's for these. :mad: :confused:
Can anybody help me find the spec's OR know what they are?
latin monkey
Re: Mercury 60 - Torque Spec's
i have the same motor as you. i'll look in my merc manual when i get home and post them for you
Faztbullet
If i remember correctly its 70 INCH pounds...............
BassnKY
Thank You latin monkey.
I will watch for your reply.
fatzbullet: Thank You! Which one is 70 in-lbs? I did find a mechanic and he said the exhaust was 200 in-lbs. It was the only one he could find. Needless to say, if it was the "only one he could find", I am not sure I trust it. I would think each one would be slightly different... Or at least the exhaust would be higher due to the higher pressure in that area.
But I want to make sure I get them all correct,
latin monkey
exhaust covers: size-5/16 is 200 in. lbs.
size-1/4 is 115 in. lbs.
transfer cover: 160 in. lbs.
cylinder block cover: 70 in. lbs.
BassnKY
latin Monkey:
GREAT!!!! :) :D :)
THANK YOU for the info!!!
