marshcreeper
- Jun 11, 2010
- 3
1995 Johnson 70HP, motor will no longer shift to reverse. gears grind. When manually shifting at motor with cables disconnected, will easily shift from neutral to forward and stay in gear. However, slighlty harder to shift from neutral to reverse, and will only stay in reverse if i hold the shifter lever on the motor in the reverse position? Otherwise will pop itself back into neutral. Any help would be appreciated.
