Re: 1975 merc 850 will not start
If the battery is charged and still nothing, try jumping the solenoid with a screwdriver to see if that works. With the key on it should start and stay running. If thats the case you probably have a bad switch in the start position. If when you jump the solenoid it won't run, you may have a bad switch period.
